http://www.aboutprojectors.com/Epson-EB-X7-projector.html
ok upgraded to this projector...just wondering do i set my second screen or main display to the same resolution to 1024x768 as projector..i know whatever connevtion i use for input on projector gives a different display size
thanks guys
thanks guys
geposted Fri 21 Jan 11 @ 2:18 pm
Most laptops or desktop support multiple monitors, also the let you set the resolution of each monitor differently. So set your monitor at its native resolution and your main monitor at its native resolution. make shure that you do not duplicate your desktop on both monitors but choose extend desktop instead.
geposted Fri 21 Jan 11 @ 3:11 pm
grand thanks mate...just wasnt sure about resolution settings from lappy to projector....always use external but cheers for the answer mate
geposted Fri 21 Jan 11 @ 5:00 pm
