What are you guys using to sync your backups accurately?
Fixing tags, and adding music on your primary's, how are you getting this on your secondary drives without doing the whole manual cut and paste thing?
geposted Sat 22 Jan 11 @ 4:01 am
update your main machine ect then straight after close vdj then copy your up to date xml file and copy the file to your second vdj documents on 2nd machine
geposted Sat 22 Jan 11 @ 4:06 am
I use FreeFileSynch for MP3, data files and some more stuff.
Works great, it's free, you can get it at http://sourceforge.net/projects/freefilesync/
geposted Sat 22 Jan 11 @ 6:07 am
Goodsynch is very reliable and constantly upgraded.. Just Google it..
geposted Sat 22 Jan 11 @ 8:17 am
I use a robocopy script. Robocopy is builtin Windows 7. For XP and Vista you could download a version for free at the Microsoft website.
geposted Sat 22 Jan 11 @ 8:36 am
Robocopy is cool, but I use DSynchronize v2.30.1: http://dimio.altervista.org/eng/
I like the specs of FreeFileSynch, might try that one next.
thanks,
David
DJ Kavika
thanks,
David
DJ Kavika
geposted Tue 25 Jan 11 @ 1:47 pm
SyncBack !!!!
http://www.2brightsparks.com/downloads.html
geposted Tue 25 Jan 11 @ 2:04 pm
Found SyncToy from microsoft! Works great!!! Thanx for all your replies.
geposted Tue 25 Jan 11 @ 2:21 pm
I too used SyncToy but it doesn't make exact copies of backup. Goodsync is better.
geposted Wed 26 Jan 11 @ 3:46 am
File Synchronizer its free and it works...http://www.latshawsystems.com/Products.aspx
Joey...
Joey...
geposted Wed 26 Jan 11 @ 8:09 am
@djfilosoff - have you tried 2.1? If you set it up to "echo" not "sync', it works perfectly! Especially since I work of the master drive and only require a mirror image on the back-up!
geposted Wed 26 Jan 11 @ 1:55 pm
geposted Wed 26 Jan 11 @ 4:11 pm
