Hey guys there no sound coming out of my amp at the moment im not sure if its blown or what..
im using a studiomaster 1200 watt amp and when i turn it on all the lights come on no problem then when i turn up the amp and then the music theres no sound.. the green indicator light stills comes out but no sound any ideas? blown maybe?? i have checked all the wires and they are correct so im a bit stumped!!
Dj muppetjnr
Dj muppetjnr
geposted Sat 22 Jan 11 @ 10:27 am
check the internal fuses.
geposted Sat 22 Jan 11 @ 5:33 pm
sorry to HEAR about your deafness ....
WHAT?
WHAT?
geposted Sat 22 Jan 11 @ 5:38 pm
it's eithere your connections or your speaker has been electrocuted and wlll have to plan a wake at the repair shop...
Sorry for your loss.....
Joey...
Joey...
geposted Sat 22 Jan 11 @ 5:59 pm
Volume knob on mixer! sorted
On a serious not I like those Studiomaster amp's for the price.
geposted Sat 22 Jan 11 @ 7:41 pm
Hi mate
If you are getting a signal indication on the front panel but no sound: Check speakers and speaker cables. Make shure the amp has not been switched into bridge mode. Not shure which Studiomaster amp you have (post the model please) The 1200D for example has a pair of led's on the front (One for each Channel) which show when the amps circuit protection is operating. This can indicate anything from a short circuir speaker lead to a fault in the amp. In normal operation these leds will come on when you first switch on and go out (Acompanied by a click from the internal protection relays) to show that the amp is ok.
If there is no signal indication on the front panel try pluging the output from your mixer or soundcard into another amp (even your hifi will do) If you get sound then the amp may well need repairing.
Daz
Daz
geposted Sun 23 Jan 11 @ 12:01 am
thanks for al the feedback guys it gone to the repair shop so fingers crossed:)
geposted Mon 24 Jan 11 @ 5:11 am
