If i bought two mk2's would they be able to be used on VDJ like the 850s?
geposted Sat 22 Jan 11 @ 3:23 pm
No, unlike the 850, CDJ 800's aren't MIDI/HID controllers and cannot directly control VirtualDJ in any way. They can only be used by using timecode CD with a suitable 4-in/4-out ASIO sound card such as Hercules DJ Trim.
You will need to upgrade to VirtualDJ Pro to use MIDI controller or timecode: https://virtualdj.com/buy/
geposted Sat 22 Jan 11 @ 4:17 pm
