I had originally tried the home version and had no problems whatsoever. I purchased the pro version as I am a mobile DJ/VJ and wanted to be able to use the software with a projector. I have searched on the forums and have not found anything that has helped - everytime I use sonique the program (VDJ) locks up on me, and I am forced to end the process. What do I need to do in order to get this to work without problems? I can't have it doing this while on a gig as it is a royal pain, and would look extremely unprofessional.
My system information is:
Gateway SX2801
Pentium Dual Core CPU E550 @ 2.80 Ghz 2.80 Ghz
6gb Ram
64 Bit
Intel GMA X4500MHD Integrated Graphics
This is a slimline desktop PC.
Any help is EXTREMELY appreciated! I am just hoping I didn't waste $299 buying the software!
Gateway SX2801
6gb Ram
64 Bit
geposted Sat 22 Jan 11 @ 11:17 pm
Make sure that you are using the certified plugins only: https://virtualdj.com/addons/4207/72_Sonique_Visual_plugins_certified.html
If you use uncertified plugins, then you may experience problems, especially if you also have WinAmp installed.
geposted Sun 23 Jan 11 @ 12:33 pm
yeah I'm only using the pluggins I downloaded from the VDJ site - and I do not have WinAmp installed.
geposted Sun 23 Jan 11 @ 1:51 pm
Look at the pic,
Open the "Video Effect" tab to see it.........
Hope that helps
Huey
Hope that helps
Huey
geposted Sun 23 Jan 11 @ 2:48 pm
Ok I did that - and ended up deleting all but three of the visualizations! Is there some sort of error report or hang app report that I would be able to post here? I know DiscoXT has one (That's the software I used prior to VDJ). Any help is appreciated!!
geposted Sun 23 Jan 11 @ 3:05 pm
Hmmm, thats werid, anyways go into your VDJ folder and look for a file named "Crashguard Report". Copy that and post it, DJCel or someone will check it out. You wont get an answer right away but I'm sure they'll report back.
Huey
Huey
geposted Sun 23 Jan 11 @ 3:09 pm
Hmm - there is no file called crashguard, although there is an application for it. The program (VDJ) hasn't shut down on it's own - it just totally locks up so I can't do anything, and then I am forced to end process
geposted Sun 23 Jan 11 @ 4:29 pm
could it be related to the graphics card I have in my computer?
geposted Sun 23 Jan 11 @ 4:31 pm
bump
geposted Mon 24 Jan 11 @ 8:26 pm
