Hello DJ's :)
I am using the Home Version of virtual dj 7 and have a problem with the hotcues.
The problem is only on Deck 2. I am using the skin: "Virtual DJ 7 (2 Decks) 1280x768"...
The problem is:
On deck 2 when i have all 3 hotcues added and i want to replace one (by rightclicking on the skin) then it replaces the wrong one?
If i rightclick on hotcue 2 then it replaces hot cue one???
Hope you can help...
DJ Rostami
The problem is:
DJ Rostami
geposted Sun 23 Jan 11 @ 10:47 am
Yes you are right, there is a bug there. Actually all Hot Cues on deck 2 do not set Cue properly.
Team will upload an update soon...
but in the meanwhile you may edit the xml file
Find
<button action="deck 2 hot_cue 1" rightclick="deck 2 set_cue" >
Replace with
<button action="deck 2 hot_cue 1" rightclick="deck 2 set_cue 1" >
Find
<button action="deck 2 hot_cue 2" rightclick="deck 2 set_cue" >
Replace with
<button action="deck 2 hot_cue 2" rightclick="deck 2 set_cue 2" >
Find
<button action="deck 2 hot_cue 3" rightclick="deck 2 set_cue" >
Replace with
<button action="deck 2 hot_cue 3" rightclick="deck 2 set_cue 3" >
Find
Replace with
Find
Replace with
Find
Replace with
geposted Sun 23 Jan 11 @ 4:35 pm
THANK YOU!!! :) You made my day :)
geposted Mon 24 Jan 11 @ 7:37 am
