Hi;
I plan to buy a laptop and a good soundcard like maya 44 or another one (I don't know which one yet).
As the Maya 44 has 4 mono inputs and 4 mono outputs, if I want to use 3 of them (deck A, deck A, sampler), I guess I use 3 mono outputs instead 2 stereo. With this config what settings do I have to select in the advanced section ? The two lines (for left and right) must be configured on the same soundcard output ?
geposted Sun 17 Jul 05 @ 11:26 am
If I were you, i would buy a soundcard with 3 stereo outputs, you will have a better sound, and if you aren't planning on using the TCVs or TCCDs then the maya44usb won't be very much as a use, because you can find 3 stereo outputs cards cheapper with a same quality.
geposted Sun 17 Jul 05 @ 4:43 pm
clax - as lej78480 said, if you don't plan on needing the inputs then get something like the AudioTrak GigaPort, it is basicly the Maya but with all outputs - 8 MONO/4 STEREO.
cstoll
cstoll
geposted Sun 17 Jul 05 @ 8:27 pm
Yes but the price of the Gigaport is twice the Maya 44.
Do you have another ideas ?
That's right I don't plan to use TCV or TCCD.
I just want to have a good sound, good level (much than a basic soundcard) comparatively to a CD player.
geposted Mon 18 Jul 05 @ 11:01 am
Hm.. for non-tcv/tccd, music-in-VDJ only, I could recommend SB Audigy 2 NX USB. It has worked fine for me so far. The should come at a resonable price.
geposted Mon 18 Jul 05 @ 12:15 pm
Thanks for this advice.
And what about this one: Sound Blaster Audigy 2 ZS Pci 24 bits ?
geposted Mon 18 Jul 05 @ 3:48 pm
Yep, i suppose its good enough...really high quality stuff.. snr >102 db...pretty good card for pci.
geposted Mon 18 Jul 05 @ 5:14 pm
Even better. Less cords, adapters etc.
geposted Mon 18 Jul 05 @ 6:23 pm
Hmmm it seems it doesn't exist any USB soundcard at about 100 euros with 3 stereo outputs ... It's a shame.
Having 2 good stereo outputs with a MAYA USB and the sampler with the integrated soundcard will probably get a big level difference between these 2 ones.
geposted Tue 19 Jul 05 @ 5:05 pm
What about soundBlaster Extigy? Did you check that? I think its 7.1 channel, meaning 3 stereo outputs.
geposted Tue 19 Jul 05 @ 5:29 pm
clax if you want to Ban creative cards
have a look at http://europe.hercules.com/showpage.php?swcty=UK&p=84&b=1&f=1
it's hercules usb soundcard, looks nice, don't know the quality but as far as I know all herc sundcards are good (HDJC has a good sound too)
but I did not find a price of this soundcard
geposted Tue 19 Jul 05 @ 7:10 pm
Hmm.. Firewire interface though, but sure enough for your needs. :)
http://www.edirol.com/products/info/fa101.html
I'd guess you have to pay more than $100 for it, but you would certanly have one of the better cards ;)
geposted Tue 19 Jul 05 @ 7:33 pm
Cool but more expensive.
geposted Tue 19 Jul 05 @ 7:42 pm
After a lot of searches ...
What do you think of this one:
http://sounden.terratec.net/modules.php?op=modload&name=Sections&file=index&req=viewarticle&artid=319&POSTNUKESID=7226399cdfb7e8887f7057bab41dbd0a
Does anybody tried it here ?
Do you think it's enough to play with other CD players on the same mixtable ? (86db at 44.1Khz)
Thanks in advance.
Clax
Thanks in advance.
Clax
geposted Wed 20 Jul 05 @ 7:53 am
The Hercules Console is a GREAT usb soundcard (24bit, cristal clear sound) - and includes an ok midi controller for VDJ.
If not using timecode, I would recommend the Hercules soundcard anytime, and you will get the midi controller included (an ok controller)
Hercules gives you USB soundcard with 3 stereo outputs
geposted Wed 20 Jul 05 @ 10:05 am
Yes but I use VirtualDJ with an external mixtable and the Hercules Console is a bit expensive in that case maybe.
geposted Wed 20 Jul 05 @ 2:51 pm
might be yes :)
I use Hercules Console with external mixtable (see pics in my blogs), just because I love the jogwheels at the console for nudge (all I use at the console actually, + the included soundcard)
geposted Wed 20 Jul 05 @ 3:04 pm
Me too. I use Console only as soundcard and its jog wheels. Thanks to dj-in-norway. He told me how to use Console in combination with external mixer ;)
Will put pic in my blog soon.
Dj Nikki
Dj Nikki
geposted Wed 20 Jul 05 @ 4:06 pm
Maybe I'm gonna change my mind.
geposted Wed 20 Jul 05 @ 4:25 pm
