Currently using VDJ Home and sourcing my stored music from Windows Media Player(personal preference:P) VDJ pulls all my albums and downloads from the drop down folders fine but when I make an exact playlist in WMP and save it VDJ doesnt show it when mixing, its as if its not registered I have saved a playlist?
any takers?
any takers?
geposted Sun 23 Jan 11 @ 4:32 pm
Sorry, Windows Media Player playlist format is not supported by VirtualDJ. VirtualDJ uses standard .m3u format, as also used by WinAmp, etc.
To use a Windows Media Player playlist in VirtualDJ, you will need to convert it to .M3U format:
(1) In Windows Media Player, click Library.
(2) In the Contents pane (The left pane), expand the My Playlists category, and then click a playlist.
(3) On the File menu, click Save Now Playing List As (Save Playlist As in Windows Media Player 9 Series), click Save as type, and then click M3U Playlist (*.m3u)
(4) Browse to your VirtualDJ playlsits folder (My Documents\VirtualDJ\Playlists)
(5) In the File name box, type a file name for the M3U playlist, and then click Save.
geposted Sun 23 Jan 11 @ 5:14 pm
