Ok I am doing a gig ant this older club. Running a 50ft VGA cord to the the 65in LCD. For Some dam reason when I have my VMS pluged into the laptop it seems like its ground out bad? makes my computer video card go nuts? Now this is the 1st time I tried this here at this place. I tried different ports even a usb hub!!! Same problem..it seems the VMS 4 is causing the problem? When I disconnect it I can run video's fine? when I reconnect it I get that grounding look on the TV and my video card resests ever 2 min? Could it be the wireing form the old building? and what can I do to fix it??
Thanks in advance....
geposted Sun 23 Jan 11 @ 7:55 pm
You are getting noise in your audio because the TV's are on a different circuit then your laptop. Try plugging it in somewhere else or try lifting the ground on the tv's had the same problem at my club ended up running an extension cable over to the tv's and plugging the laptop into that.
geposted Sun 23 Jan 11 @ 8:10 pm
Thanks for the quick reply..I was going to try a power conditioner also but will try your suggestion.. thanks again..
geposted Sun 23 Jan 11 @ 8:16 pm
