I installed and gave VDJ 7.0.2 a run for its money Saturday night and only had 1 problem with it...it lost connection to the controller (Denon HD2500) after about 1hr 45 minutes. I was hesitant to have it rescan while playing so I mixed into a DVD, took the controller out of Midi mode, reapplied midi mode, then had VDJ rescan for controllers and it found it thus re-establishing connectivity without crashing VDJ. When I did the same procedure before with pre 7 VDJ would crash.
I was not using the DN HD2500 as a soundcard, just as a controller.
I do not consider this to be a "MAJOR" issue because I always have a backup cd/dvd video ready to go just in case.
Besides this one hiccup, which might be an isolated event, VDJ 7.0.2 is rock solid!!!
geposted Mon 24 Jan 11 @ 7:39 pm
Do you have the latest firmware installed from http://www.denondj.com ?
geposted Wed 26 Jan 11 @ 1:03 pm
Probably not...the unit isn't mine. I will check on it and have the latest firmware with me along with the instructions to perform the update if it is lacking. Is the latest version 7/11/2008 ??? That's the date of the HD2500.bin file.
geposted Wed 26 Jan 11 @ 2:54 pm
The most recent is published on Denon's site: http://www.denondj.com/firmware.aspx?ProductId=80
However, the version above may actually be newer than this!
geposted Thu 27 Jan 11 @ 12:43 pm
Interesting. I downloaded the firmware (only one I saw listed) that was listed and when I extracted the Zip file he dates all said 2008.
geposted Thu 27 Jan 11 @ 2:13 pm
