I am aware that to use the NS 7, a certain Laptop Spec is required. I would just like to know is anyone using the NS 7 with lower specs?
Minimum Requirements For PC: (This is what I use, would like a Mac but to much moola)
-Windows 7 64 Bit OS, 4GB, 2.4GHZ, 3MB L2 Cache Core 2 Duo
I have: (Sony VAIO)
-Windows 7 64 Bit OS, 4GB, 2.2GHZ, 2MB L2 Cache Core 2 Duo
HELP ME OUT!!!
I have: (Sony VAIO)
HELP ME OUT!!!
geposted Mon 24 Jan 11 @ 10:23 pm
It can be done if you don't use keylock and don't mind max latency. I would not recommend it. Get the fastest processor possible and you will not be sorry. I run a 3.2ghz i5 Intel desktop Win 7 64 bit and never looked back. This PC can run 256 (middle point) latency. I am convinced it is not possible to get bellow that running VDJ and keylock, without blowing thousands on a PC.
I tried a Viao with Win 7 64 bit, 6 gig ram, i7 1.7ghz (2.8 speedboost) and it was horrible. I returned that laptop. I am sure yours runs great but the NS7 is a pig on resources and I was not getting rid of it.
geposted Mon 24 Jan 11 @ 10:34 pm
TY Bruh...I hear that. I believe that VAIO you had acted like that because it was 1.7 with a burst of 2.8GHZ. If I am not mistakin I spoke with a rep one time and he said that laptops with burst won't work to good. Well I am gettin my NS& back anyway. I had one and gave it back bout 8 months ago I miss it lol....b/ of my other laptop.
geposted Mon 24 Jan 11 @ 10:42 pm
I just remembered something. I used to own a Dell 1501 laptop and they come with core 2 duo 1.8 and 2.0 ghz processors. It comes with Vista 32 bit home or premium. You can find one from 150 thru 300 dollars used on craigslist. If you can get a 2.0 ghz, you will be good to go.
The Minimum specs for a 32 bit system is 1.83ghz core duo with 2 gigs of ram.
geposted Mon 24 Jan 11 @ 11:21 pm
Yeah I found one for 450 HP prbook 32 bit windows 7 2.4 ghz 3mb l2 cache
geposted Mon 24 Jan 11 @ 11:42 pm
2.4 ghz for 450 is good. Do a Caliente and offer less.. LOL
geposted Tue 25 Jan 11 @ 12:03 am
lol its at tigerdirect
geposted Tue 25 Jan 11 @ 12:08 am
Minimum System Requirements:
Windows
* 32-bit
Windows 7 / Vista: Intel* processor, 1.8GHz Core 2 Duo; 2MB L2 cache; 2GB RAM
Windows XP: Intel* processor, 1.8GHz Core 2 Duo; 2MB L2 cache; 1GB RAM
* 64-bit
Windows Vista: Intel* processor, 2.2Ghz Core 2 Duo; 2MB L2 cache; 4GB RAM
Windows 7: Intel* processor, 2.4GHz Core 2 Duo; 3MB L2 cache; 4GB RAM
* 1024 x 768 screen resolution
* Available USB 2.0 port
* Available Hard disk space for music
Macintosh
* Mac OS X 10.6
32-bit: Intel processor, 1.8GHz Core Duo; 1GB RAM
64-bit: Intel processor, 2.4GHz Core Duo; 4GB RAM
* Mac OS X 10.5 / 10.4.11
Windows
* 32-bit
* 64-bit
Macintosh
* Mac OS X 10.6
geposted Tue 25 Jan 11 @ 2:55 am
