hi everybody, i just bought mac and console.
i downloaded last drivers and i installed cd program on my mac, but i really cant make it work.
program is running just with mac keyboard, and i can't use the controller, it just doesn't get any change.
i plugged it to my mackbook air usb port.
i can see the logo switched on my console, but seems like it doesn't exist.
can u please help me.....?
thank you!
thank you!
geposted Tue 25 Jan 11 @ 1:10 pm
Have you tried both USB ports of the MAC Book ?
Is this with and without the power adapter connected ?
First, check that the MK4 is correctly installed, as described in this document:
http://ts.hercules.com/faqs/eng/her_eng_00404.pdf
If everything seems to be correct, then test it as a MIDI controller:
geposted Wed 26 Jan 11 @ 8:32 am
