Fire Text Plugin shows up under VIDEO EFFECT of VDJ but nothing on the right side just a grey square?? help PLZ
my system
Windows XP
Service pack 3
dell Inspiron M1710
Intel (R) Core (TM) 2 CPU
2 GHz 2 GB of RAM
THX
Bob F
my system
Windows XP
Service pack 3
dell Inspiron M1710
2 GHz 2 GB of RAM
THX
Bob F
geposted Tue 25 Jan 11 @ 2:02 pm
Hi, do all your other visual effect plugins work ok? if not you need to install dx9 or try a reinstall, same applies to the free Firetext plugin.
geposted Tue 25 Jan 11 @ 2:16 pm
Hi Tayla, I will let Bob know I was with him when he tried works on both my lappy's
THX for quick reply
THX for quick reply
geposted Tue 25 Jan 11 @ 2:46 pm
yes...other effect plugins work ok...
geposted Tue 25 Jan 11 @ 4:02 pm
I installed dx9....still does not work...next i will reinstall firetext......I will let you know if that works!
geposted Wed 26 Jan 11 @ 10:22 am
we have installed direct x 9 and reinstalled firetext STILL NOT WORKING same as before
could it be NVIDIA GeForce Go 7900 GS??
thanks
thanks
geposted Tue 08 Feb 11 @ 12:24 pm
Can you try this if possible, try plugging in a usb camera and use the camera pluggin, another user had this problem on his dell, but once he plugs in the usb camera he can see the Firetext pluggin.
Weird I know, but it must have something to do with Dell, as you already know by getting the pluggin to work else where.
geposted Tue 08 Feb 11 @ 3:02 pm
Hi tayla will try THX I'm the guy helping BOB....it is weird but will try he also has a couple of ver of VDJ on this lappy...5.2 & 7.0.2 did not know if that might be the reason....
DJ M.A.
DJ M.A.
geposted Wed 09 Feb 11 @ 7:01 am
