Hi , is there anyone here that i can hire to make a custom skin for me ?
I dont need anything much complicated , i work with 4 decks video and many of the skins here have a lot of options that i dont even use .
It will be something similar like V-mix Skin but for 4 Video Decks .
Best of all
Pedro
Best of all
Pedro
geposted Wed 26 Jan 11 @ 2:26 pm
I am planning to update one of my video skins to 4 decks soon. Check out Plasma https://virtualdj.com/addons/11720/Plasma.html
geposted Wed 26 Jan 11 @ 2:34 pm
thanks a lot for the fast reply , your skin is cool but i needed something more simple .
Anyway , i cant wait to try your 4 decks video skin upgrade you will make maybe removing the controls from skin could help you to arrange the space for the other 2 decks needed .
by the way , i was looking for the "Setup" button on the primary skin and i could not find it !!!!
You left that option to be used as keyboard shortcut ?
Thanks a lot for you help ill keep looking here when i get free time .
Best of all
Pedro
Best of all
Pedro
geposted Wed 26 Jan 11 @ 3:54 pm
Look at the right side, on the white thick line, on the top of the playlist. You cant miss it!
geposted Wed 26 Jan 11 @ 5:10 pm
geee you are right i really missed it .
In Normal state is a clear grey under a white bar and only on mouse over it turns black .
Thanks for the tip
Happy week
Pedro
Thanks for the tip
Happy week
Pedro
geposted Wed 26 Jan 11 @ 6:05 pm
