Here is what I already have for my new build:
SAPPHIRE 100315L Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
AMD Phenom II X6 1075T Thuban 3.0GHz Socket AM3 125W Six-Core Desktop Processor HDT75TFBGRBOX
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power
I want this computer to be dedicated to my DJing (karaoke and video).
What suggestions can you give me? I still need a mobo, soundcard, hard drive, etc...
Thanks for your help!!!
geposted Wed 26 Jan 11 @ 4:55 pm
a case, a power lead, a maya 44 pcie card or julia pcie. a keyboard and mouse.
oh and some ram (about 16gig) would be nice so would bluetooth and an IR and fm reciever for use with remote controls iphones etc...
oh oh oh ............a harddrive and OS.
you dont even really need a case you could build a fishtank pc with mineral oil to keep it mega cool. it would look great churning away with a uv light inside at a gig.
edit:
graphics card or 2 would be usefull too rather than rely on the onboard.
edit:
geposted Wed 26 Jan 11 @ 5:45 pm
Once you buy this case, you will not even look at another case http://www.frozencpu.com/products/6009/cst-544/PC_Design_Lab_Qmicra_v2_Rev_F_Micro-ATX_Liquid_Cool-able_Case_QV2F.html
The new version F, is the latest. I built 2 of these, One for me and one for my best friend. I have 5 hard drives, and am thinking about getting rid of the DVD drive, then I will have six.
Blulite, he has a graphics card. The first item he mentioned.
geposted Wed 26 Jan 11 @ 5:53 pm
i really beg to differ on that my friend. it looks like a deathstar's turd. or darth vaders other mask.
not only is it horrid, its 250 bucks and out of stock. ive seen better cases for a lot less.
personal preference obv, but thats deffo not my style.
plus it dont have usb 3 support. which is going to be a major factor in any setup at the moment.
http://www.overclockers.co.uk
have a huge range of cases and theyre well priced for the spec too.
geposted Wed 26 Jan 11 @ 6:05 pm
That is a nice case. I should have mentioned I am going with rack mount case.
Ram is a given, DDR3 1600 and over clocking is a must.
hard drive, 1 - 80Gb SSD and 2 - WD 300Gb 10,000 RPM.
My biggest dilemma is the mother board and the sound card.
Thanks
Thanks
geposted Wed 26 Jan 11 @ 6:09 pm
for a motherboard you want it future proof so try and get one with e-sata and usb 3.0 support maybe fire wire if possible. with e-sata the data transfer rate is by far supreme to any usb. iw would give you that piece of mind for using external hdds without any chance of lag.
soundcards,
esi maya 44 pci-e
or
esi julia pci-e
soundcards,
esi maya 44 pci-e
or
esi julia pci-e
geposted Wed 26 Jan 11 @ 6:13 pm
drclean, glad you liked the case. It's a quality case built in the US, by a small company. You get what you pay for. I looked into rack mounts, but they do not transition well to the desk, when I had to add content. They are quite large, and if you put it in a rack case, they did not fit into some of the skimpy booths I had to work in. Glad to see another builder on the forums. Check out some of the mods of this case. I have had good results with ASUS motherboards. Good luck with your build, and show us the finished product.
geposted Thu 27 Jan 11 @ 3:05 am
I do like that case AMaHM, I also have an ASUS Rampage Gene II and I love it, and I know that they also came out with the III.
geposted Thu 27 Jan 11 @ 10:19 am
I was trying to decide between GigaByte and ASUS. My last 2 builds were GigaByte and I had very few problems but still it was a few problems. So thank you for help, I am going to buy ASUS, although I won't use the Rampage it is a very NICE mobo. I will actually use it's AMD version.
Now an additional question. Do you guys use projectors? If so what kind?
Thanks
Thanks
geposted Thu 27 Jan 11 @ 5:32 pm
