Does someone has a custom mapping fot this controller ?
geposted Thu 27 Jan 11 @ 7:35 am
I know it is mapped by default.
But I'm not able to use the auto learn function to change the default mapping in vdj, any help appreciated.
geposted Thu 27 Jan 11 @ 12:02 pm
I just got one of these today, and I'm also having trouble mapping it.
It's detected as a VCI-100, and some of the controls are off. EQ Hi maps as gain. EQ Mid maps as eg_high. Cue maps as PFL. Etc., etc.
So, I try changing the settings in the mapper, and most of the changes just refuse to stick. I can change one setting, but then the one I set before that reverts.
Help, please. Thanks.
geposted Thu 27 Jan 11 @ 12:59 pm
I'm happy that I'm not the only one with this problem.
Some tech folks could check this please ?
geposted Thu 27 Jan 11 @ 3:19 pm
Wierd, I can not read the last message from the moderator.
geposted Fri 28 Jan 11 @ 4:12 am
I leveled it to not confuse you more. It's a link to a VCI but as you said you need VCM-100.
Greets, Heiko
Greets, Heiko
geposted Fri 28 Jan 11 @ 4:45 am
I saw the link is wrong.
No idea yet why I can't map it to my feelings ?
geposted Tue 01 Feb 11 @ 6:52 am
Does anyone have a work-around until this issue is fixed? Would I be able to use this controller with VDJ6 until there's a fix?
geposted Fri 04 Feb 11 @ 12:33 pm
Ok, so I decided to try using this controller again, since there's been a new patch. The good news is now my changes stick, so I can set my controls correctly. The bad news is, besides still being detected as a VCI-100, the decks are swapped. The controls control the opposite deck in VDJ. If I could fix this, I think I'd be set.
Edit: I managed to fix it myself with some script I found here for switching decks. I assigned this script to a keyboard key, and hitting it fixes my swapped deck.
action_deck 2 ? deck 4 assign_controller 1 & deck 4 rightdeck : action_deck 4 ? deck 2 assign_controller 1 & deck 2 rightdeck : action_deck 1 ? deck 3 assign_controller 2 & deck 3 leftdeck : action_deck 3 ? deck 1 assign_controller 2 & deck 1 leftdeck
Thanks to whoever put this scripting together! I wasn't paying attention when I copied it.
geposted Thu 11 Aug 11 @ 8:40 pm
Well, I spoke too soon. Today that script isn't working for me. Any scripting gurus willing to help?
Edit: Looks like this works, for the time being: deck 1 assign_controller "VCI-100" rightdeck & deck 2 assign_controller "VCI-100" leftdeck
Edit2: That isn't working. As soon as I touch the other deck on the controller, the controls become reversed again. What's going on?
geposted Sat 13 Aug 11 @ 12:37 pm
