Greetings. When using my Macbook Pro and 2 CDJ-400s every so often the decks will revert back to one. The music stop because it goes back to a single output, I have to go to the sound setup and click apply to get it back. Has anyone out there experienced this or has any reason why it does this? Any help will be greatly appreciated.
Thanx.
Thanx.
geposted Thu 27 Jan 11 @ 12:59 pm
does the drop out happen when u search for a song?
geposted Fri 28 Jan 11 @ 10:27 am
Yes
geposted Fri 28 Jan 11 @ 4:54 pm
Then i suggest you doing is repair permissions,
its located in disk utility.its like windows disk cleanup.
its actually worked for me it has not giving me any problems at least for a month now
and i have been using vdj 7.02 for about a month now non stop
vdj 7.02
macbook pro 10.6.6
c2d 2.66 8gb ram 750gb drive
cdj-400 midi setup
vdj 7.02
macbook pro 10.6.6
cdj-400 midi setup
geposted Mon 31 Jan 11 @ 12:47 pm
Why does this happen during the search?
geposted Mon 31 Jan 11 @ 11:59 pm
i had an issue with my external drive
every time i would search for a song(within this drive) it would happen
and like i mentioned it has not been happening ever since i did.............
geposted Tue 01 Feb 11 @ 11:41 am
i can add to this by saying
if there are services like for example...... air.. wifi you know sh!#@# you dont need i suggest you stop all of them .
That would help release any stress your mac has lol
geposted Tue 01 Feb 11 @ 11:44 am
Thanks a lot. I'll try it tonight.
geposted Thu 03 Feb 11 @ 6:23 pm
