I can't seem to get my CD players to work (be heard) when connected to these inputs.
I have the LINE-PHONO switch set to LINE on the RMX.
I know I have to press the Source 1 or Source 2 button to allow the CD players to be heard.
But it seems to have no effect.
This is the syntax for the SOURCE button in the RMX Mapper: get hastimecode ? timecode_bypass : get haslinein ? linein : nothing
It should be the factory default, as I haven't modified it.
Do I have to use LINE-IN on the Inputs in the Sound Setup tab?
Any suggestions on how I get my CD players to work?
geposted Thu 27 Jan 11 @ 9:09 pm
Yes, in VirtualDJ v7 you must choose Inputs: Line-INs to use line inputs.
geposted Fri 28 Jan 11 @ 8:00 am
Ok, thank you. Good to know. Obviously, you also have to select those inputs in the Advanced tab pf the Hercules RMX Control Panel, I assume?
(2 minutes later)...
I did, and it works. Thanks again.
geposted Fri 28 Jan 11 @ 11:27 am
