i cant open VDJ or even use it.. i just finish downloading home version VDJ but right after i open it ders an error saying "Skin log error" pls help!
geposted Fri 28 Jan 11 @ 6:02 am
If you get the error Invalid skin error line 0, then the most common cause of this error is installing the software while logged in as one user (E.g: Fred) and then trying to run it as a different user (E.g: Joe.)
The other user is missing the My Documents\VirtualDJ folder. The program will not run without this.
To resolve, please either:
(1) Install the software as the user you will be running it as.
(2) Manually copy the My Documents\VirtualDJ folder across to the other user.
Another cause is installing the software without administrator privileges under Vista or Windows 7. Right-click on the VirtualDJ installation file and choose Run as administrator. Also, we would recommend turning off UAC (User Account Control) in Windows Vista and 7.
geposted Fri 28 Jan 11 @ 10:58 am
