Hey guys is there anyways to speed up my laptop faster? cause i use Sony E Series Laptop
LAPTOP: SONY E
Intel (R) CORE (TM) i5 CPU M430 @ 2.27 GHz 2.27
MEMORY RAM (4.00GB) (3.85GB USABLE)
System Type: 64 Bits
Equipment:
Numark V7
Hercules RMX (Soundcard to my external mixer)
Virtual DJ PRO 7
It works fine but I would not trust Hercules RMX running of the soundcard because the sound quality is so bad, and slow down my laptop speed and taking up with Numark V7.
So i was wondering if I had Hercules DJTrim 4&6 as my soundcard it wont lag as much? right?
Hey guys tell me what good programs to clean out the system like spyware etc..
LAPTOP: SONY E
Equipment:
Numark V7
Virtual DJ PRO 7
geposted Fri 28 Jan 11 @ 10:04 am
To "speed up" your system, apply the changes explained in this guide:
http://ts.hercules.com/faqs/eng/her_eng_00364.pdf
As for the soundcard, I'm not sure I'm following your logic here. You don't like the soundcard quality of the Rmx ( and you have 2 of them according to your profile) , and you want to move to the DJ Trim, which is essentially the same soundcard but without the controller part...
Have you ever made any changes to the ASIO settings ?
geposted Fri 28 Jan 11 @ 2:51 pm
