Im getting crackling sounds since installing 7.0.2 on both the RMX and the MC6000. Never had crackling with RMX before so im hoping by reinstalling 7.0 or 7.0.1 i can at least temporarily fix the issue. Where can i download these two versions?
geposted Fri 28 Jan 11 @ 6:33 pm
The only 1's that can help are here, https://virtualdj.com/contact/
Good luck
Huey
Good luck
Huey
geposted Fri 28 Jan 11 @ 7:12 pm
I always wondered what do you guys do with these downloads, delete them after you install? What's wrong with saving them, that's what I do?
geposted Fri 28 Jan 11 @ 8:57 pm
exactly ......
you can go back yourself .........?????????????????????
geposted Sat 29 Jan 11 @ 8:30 am
uuuuuhhhhhhhhhhhhhhhh , ya know you can do something besides give up .....
i said that because if you tried anything at all , you didn't say so ......
if your latency is on anything besides AUTO try that
also you may have background processes running that are unnecessary and that are causing the
problem .......
problem .......
geposted Sat 29 Jan 11 @ 8:48 am
I have tried a lot of variations to reduce the latency crackling issue with no success. I have a thread in the tech support section about this where i describe all the attempted fixes.
I dont have the older versions because i formatted my laptop and and soon after that my desktop crashed to havent been able to get it from there.
Thanks for the link.
geposted Sun 30 Jan 11 @ 5:58 pm
