Back in the day, there were a few simple things to turn off in Win XP to make your DJ PC run smoother and faster, does anyone have a list of what to do in Win 7 to make it cruise?!
Dave-
Dave-
geposted Sat 29 Jan 11 @ 10:50 pm
There is a great website that you can turn off all your services etc....... wifi,printer,webcam and stuff worth checking out
www.blackviper.com
This is what I used and have VDJ running great on Win 7 X64 look at the tweaks section under Win 7 and you can disable all the things that are running in the background which will give you great results and have VDJ running nice and smooth.
Hope this helps you
www.blackviper.com
Hope this helps you
geposted Sun 30 Jan 11 @ 7:48 am
Also check the Win 7 Services section and do all the changes so that your system is running on the bare bones option is straight forward to follow if you need any more help just let me know.
geposted Sun 30 Jan 11 @ 8:18 am
