OK guys, I don't want to start any Mac vs. PC war here, I could just do with honest opinions and maybe some good old facts. I simply wanna get what's best out there within my budget. I am really considering buying an i Mac 21.5 inch with the following specs;
3.60GHz Intel Core i5
8GB 1333MHz DDR3 SDRAM - 4x2GB
1TB Serial ATA Drive
ATI Radeon HD 5670 512MB GDDR3 SDRAM
8x double-layer SuperDrive
Apple Wireless Keyboard (British) & User's Guide (English)
Magic Mouse
AppleCare Protection Plan for iMac/eMac
Price: €2,068.00
http://store.apple.com/ie/cart
But would it not be better to buy this custom pc instead?
Intel Core i7 PC - Rackmount PC Systems - Antec 22" EPS460 - 102356
Processor CPU: Intel i7 930 2.80 Ghz 4 Cores
Memory: 24GB DDR3 1600Mhz
Hard Disk 1: 1 Terabyte [7200 RPM]
Hard Disk 2: Optional Extra
Hard Disk 3: Optional Extra
Hard Disk 4: Optional Extra
Video Graphics Card: 1GB Nvidia GeForce 210 Silent
Optical Drives: 1 X DVD Rewriter Installed
Networking {Broadband}: Gigabit Ethernet OnBoard
Sound Card: OnBoard Sound
CPU Cooling: T/Take Water Cooled [Big Water]!€Keyboard & Mouse: Optional Extra
Operating System O/S: Windows 7 Ultimate 32 Bit
Office Software: Open Office Suite PreInstalled
AntiVirus Software: AVG AntiVirus Free Edition
Warranty Period: 3 Year Return to Base Warranty
Monitor Display: Optional Extra
Price: €2,534.00
http://www.custompc.ie/index.asp?function=CART
Magic Mouse
Price: €2,068.00
Price: €2,534.00
geposted Sun 30 Jan 11 @ 10:47 am
Echo,
Sorry to change the subject, but by chance is your name Jason Gibson? I knew a DJ Echo once.
geposted Sun 30 Jan 11 @ 12:10 pm
First off what are you going to be using the computer for and have you used a Mac before? If not it takes some getting used to, It take me a few weeks and now I feel lost on a windows machine. And second I am a Mac lover (I do have a windows desktop as a backup and to sync with the xbox as well as I have windows on a partition on my macbook pro) but will also say this.....It is hard to find certain programs if you are used to windows pc. Both of those are good systems another thing that you need to think about is how is your computer knowledge because if you know how to maintain them (Virus,Spyware,Registry) a windows computer will last you for a while. But if you do not have a vast knowledge of computer use and maintenance and want to get something that doesn't take as much maintenance get a Mac. This is my opinion, hope it helps but it's just hard to argue for one over the other.
geposted Sun 30 Jan 11 @ 12:35 pm
I have been a long time MAC user but prefer to run VDJ in Windows mainly becasue of the plugins. Also to me the PC version has always appeared to be a step ahead.
geposted Sun 30 Jan 11 @ 1:03 pm
I have heard the same about VDJ is better developed for windows as well. (well not heard but read here on the forums) But with all of the newer macs he can run VDJ on windows using Bootcamp and save $500 (don't know how 2 make the other symbol)
geposted Sun 30 Jan 11 @ 1:33 pm
That's funny how you want combine 24GB DDR3 and Windows 7 32bit, which can utilize only 3GB.
geposted Sun 30 Jan 11 @ 1:52 pm
Why would anyone not involved in serious HD video editing need 24Gb RAM. Surely that's overkill in the extreme?
geposted Sun 30 Jan 11 @ 2:34 pm
Quote :
Great point, I overlooked that. I have heard that most DAW's including VJD do not work well on a Windows 64bit though?
geposted Sun 30 Jan 11 @ 4:43 pm
VirtualDJ works OK on Windows 64-bit and has done for some time now.
However, some older hardware such as DJ sound cards may not have compatible drivers.
geposted Sun 30 Jan 11 @ 5:07 pm
I went with both. I have a 24" iMac and I use that at home, I have the pc for travel.
geposted Sun 30 Jan 11 @ 10:34 pm
i think, windows is better than MAC.
geposted Mon 31 Jan 11 @ 8:56 am
Can u elaborate a little more on why you think windows is better than mac? That is a generic statement that a lot of us Mac users would say the same thing about Mac being better than windows. Is it that u just like the OS better or do u think VDJ is better developed for Windows than Mac. I'm just curious because if it's a OS thing then we all have personal preference cause I can list a lot of reasons why I think Mac is better just as I'm sure you could with Windows. But I think the OP is implying Mac or PC when it comes to using VDJ.
geposted Mon 31 Jan 11 @ 11:07 am
My opinion, Mac is the better computer. I have had mine almost 3 years and have had a total of one problem that I resolved. I got my pc and I have had already had a major problem in the one month I have had it.
The only plus I can think of for the pc that there are more a few more effects.
geposted Mon 31 Jan 11 @ 11:30 am
Mac is a better machine however VDJ is better on Windows.
I have VDJ running on the Macbook Pro 17" in XP 32bit and it's faultless.
Bootcamping is dead easy and you have the best of both worlds in one computer
Keith
Keith
geposted Mon 31 Jan 11 @ 11:52 am
I agree with Krad except I have windows 7 on my bootcamp partition. There are some programs that I use that are only windows only. So this way I have the best machine & can use any program that I need 2 cuz I have the best of both worlds.
geposted Tue 01 Feb 11 @ 12:19 am
