Ok so I just downloaded a few effects/samplers etc., and I don't know how to actually use them or set them up in virtual dj. Basically, what do I do aftter I download them?
And is there anyway to get other specific features, like different sounds and stuff that I like? DoI have to use VDJ or can I get it from somewhere else? If so anyone know where??
Thanks
Thanks
geposted Sun 30 Jan 11 @ 7:00 pm
U open up your VDJ folder where it says skins and you take the file u downloaded and drop it in there. As far as samples you can load up any wave form to use as a sample. My buddy that owns VDJ Pro loaded up a sample with VDJ open you go to the sample page and It's a box or something u click on that will let u load another wave into that spot.
On another note all this VDJ talk has me upset that I haven't gotten my mixtrack pro yet.............
geposted Sun 30 Jan 11 @ 7:43 pm
Plugins (Skins, effects, etc ) are self extracted, self installed addons.
All you have to do is click on the Execute (Run) Button, not Save, and let it do its job.
Then you can choose a different skin from Config menu, or use the installed effects from the Effect page
geposted Sun 30 Jan 11 @ 9:13 pm
some VST and other plugins from external sources will work
geposted Mon 31 Jan 11 @ 3:34 pm
Is there a way to have side by side colorized wave patterns like serato?
I have downloaded the scratch skin but I would like to have the colorized wave pattterns.
It makes mixing a no brainer, just match the pretty colors!
geposted Wed 02 Feb 11 @ 1:13 pm
