http://www.appbrain.com/app/dj-control/com.bti.djControl
Free app that let's you control your favorite Dj Application Havent tested it to see if it works with VDJ but feel free to download and test it looks like a Hercules RMX :)
geposted Mon 31 Jan 11 @ 9:24 pm
Dj Toni 586 wrote :
Claims to work with VDJ http://www.appbrain.com/app/dj-control/com.bti.djControl
geposted Mon 31 Jan 11 @ 9:27 pm
To make it work You need a DSMI server installed on your computer you can search the net (Google) or click on settings when the app is open and and scroll down under technical and read midi to wifi
Dj Toni ,
Dj Toni ,
geposted Mon 31 Jan 11 @ 9:34 pm
You must be using 'Droid OS version 2.0 or higher....
geposted Mon 31 Jan 11 @ 9:37 pm
Looks like it :(
geposted Mon 31 Jan 11 @ 9:46 pm
Hmm...I might have to try this. My Droid X "Android Version" is 2.2.1.
geposted Tue 01 Feb 11 @ 12:49 am
Same here but read this, https://virtualdj.com/forums/142243/PC_Version_Technical_Support/DJ_Control_for_Android.html , I don't have a clue how to make those files...........
Huey
Huey
geposted Tue 01 Feb 11 @ 12:56 am
Hmmm already tried VDJ with it, it doesnt find it at all The program to broadcast the signal does....
Im with beatbreak on this one
Dj Toni
Dj Toni
geposted Wed 02 Feb 11 @ 10:50 am
I had a play with this but didn't get on with it. TouchOSC is out for Android btw :)
geposted Wed 02 Feb 11 @ 10:59 am
Scott I know you got alot going on right now, but can you expand on that alittle more, in laymans terms, lol!
Thanks for the time
Huey
Thanks for the time
Huey
geposted Wed 02 Feb 11 @ 11:39 am
Well I emailed the creator and he is making the definition file for VDJ7 and it should be released next week!!
Huey
Still would like to know how to setup Touch OSC..........
Huey
geposted Wed 02 Feb 11 @ 6:05 pm
TouchOSC is easy, although at present the Android version doesn't support custom layouts unfortunately.
Install it from the app market, and then the PC side is the same as the iPhone/iPad version.
http://hexler.net/software/touchosc
I've actually got a plugin here I've written that acts as an OSC server for VDJ which I wrote to use with the Mix2 layout on TouchOSC. No other software needed ;)
geposted Thu 03 Feb 11 @ 3:08 am
Ok I've downloaded the app but what do I need to do on the PC side?? How do they connect?
Thanks for the time
Huey
Thanks for the time
Huey
geposted Thu 03 Feb 11 @ 8:35 am
I would so love to be able to justify spending £400+ on an iPad...but to be honest I would prefer a true Android app, as you can buy Android 2.1 powered 7" tablets in Maplins for £129...so that means I could basically buy three 7" Android tabs for the price of an iPad....
The day an Atomix app for Android OS becomes available...I'll be straight down to my local Maplins and hammering the credit card...
geposted Thu 03 Feb 11 @ 9:24 am
Thanks for the time
Huey
Thanks for the time
Huey
pure data
MIDI loopback eg MIDI yoke
Pure data touchosc patch
I've got a plugin which bypasses all that but its not ready yet. My own Android app uses OSC too ;)
geposted Thu 03 Feb 11 @ 12:37 pm
SBDJ wrote :
pure data
Pure data touchosc patch;)
pure data
So I need to download all 4 of those programs!?? That's seems like alot?
Huey
geposted Thu 03 Feb 11 @ 1:35 pm
pd does the conversion from OSC to MIDI
MIDI Yoke is the virtual MIDI port VDJ and pd will see
The patch tells pd how to convert OSC to MIDI
You asked!
Like I say, I have TouchOSC talking directly to VDJ with no drivers, software or voodoo needed. I may well release this plugin in the future.
You asked!
geposted Thu 03 Feb 11 @ 2:37 pm
Lmao! Yes I did.......Scott im gonna buy you a new cape cause like I said before you are my new favorite super hero!! Definitely release that one!! Need a beta tester, lol!! No foreal ill test for you!!
Huey
Huey
geposted Thu 03 Feb 11 @ 4:02 pm
Anyone have the commands for the play and cue buttons. Tried DJ Control and Touch OSC, they work sometimes and not other times, so I am missing something. I have the fader, sync buttons working fine.
What are the commands you all are using for Touch OSC?
IE:
deck 1 cue_stop
deck 1 play_pause
or is there something more to this like:
deck 1 play_pause ? play_button ? etc...
thanks,
David
IE:
deck 1 cue_stop
deck 1 play_pause
thanks,
David
geposted Thu 03 Feb 11 @ 8:37 pm
Ok, found this is correct for the play button:
"deck 1 play_pause +1"
The +1 does not work for cue_stop, but I need something to tell it to trigger when its pressed down.
I believe that VDJ is seeing button being pressed and released?
thanks,
David
thanks,
David
geposted Thu 03 Feb 11 @ 8:58 pm
