I see there are buttons for the sampler on the unit. I know they are there to trigger the samples. Where do you control the volumes for the samplers?
geposted Tue 01 Feb 11 @ 11:55 am
Paramater 1 knob adjusts the sampler volume for deck 1 & parameter knob 2 adjusts the sampler volume for deck 2, but only when you're in the sampler page by selecting it in the skin or by pressing the "sample" button on the MC6000
This is noted in the MC6000 manual.
If you want to do this you can map them to do that permanently, but then they lose their other functionality.
Parameter1 adjustment knob
The function differs according to the window.
• BROWSER : Selects the video transition type.
• SAMPLER : Adjusts the sample level for DECK A.
• EFFECTS : Adjusts the parameter 1 for the selected effect.
• RECORD : – (Not available)
The parameter buttons also have functionality on the sampler page too ....
Parameter1 ON/OFF switch button
(PARAM.1)
• BROWSER : Switches the video transition function ON/OFF.
• SAMPLER : Plays back the sample for DECK A. Hold o SHIFT and press this button during sample playback to play back the sample from the beginning again (Stutter function).
• EFFECTS : Enables the effect selected for DECK A.
Keith
(PARAM.1)
Keith
geposted Tue 01 Feb 11 @ 1:26 pm
