Hi Everyone,
My 1st post, so dont be too critical please.
I've looked over past questions, but nothing seems to be able to solve the problems Im having setting up my timecoded vinyl to run with virtual dj 7 pro. Im using serato timecodes by the way.
The problem im having is not with playback quality, as you'll see from the pictures below, its 100%. The problem I'm having is that I'm missing the red line from the signal, which means that if I try to scratch, the vinyl wont move backwards... which is obviously quite frustrating. Im guessing due to the lack of red input, I cant get the circles.. all i get are straight lines.
Anyone able to help? If so please let me know what I can do, and if it works, I'll buy you a pint if you're ever in town!
Thanks,
Anmol
Images
http://i53.tinypic.com/rk8mef.jpg
http://i56.tinypic.com/2eyet1s.jpg
Thanks,
Anmol
Images
geposted Tue 01 Feb 11 @ 7:46 pm
1 of cables is loose or bad. The timecode signal is a stereo signal, that's why you'd see to 2 round circles. Go back and reconnect all you cables and see what happens. Could also be the wires on your needles or the needle itself is bad.
Good Luck and Read your MANUAL it'll help you
Huey
Huey
geposted Tue 01 Feb 11 @ 8:39 pm
