I have the data base in c drive as the only database showing. I have the external 1t drive attached as a a usb. It doesnt see it, is there a way to be able to see it? Thanks for the help in advance.
geposted Tue 01 Feb 11 @ 9:20 pm
Does the external drive show up in My Computer?
Si
Si
geposted Wed 02 Feb 11 @ 4:01 am
ok, here is the deal it shows up in my computer and finds all the 35000 songs in the remix files ( Im wondering if its becauase zip dj codes the songs with numbers that some of them are not showing. I see only about 1200 of them. Thats just my remix folder.The club folder has more then that and it only show about 1500 of them. Its like after so many songs it stops showing it. I ran it on the old version on the broken lap top and it see's the entire thing. I rescanned all the music bpm and tags. I am at a loss. According to the form search others have had the same issue. I just bought a kicking touch screen and was desigining a skin when I was looking for some of the songs and noticed that they were not able to be found. I tried win amp, and search and they are still on the drive. I virus checked the drive and db scanned it but still in the config area it doesnt show that drive at all. Im using a Iomega t drive and windows 7 64 on the touch screen and 32 on this broken lap top.Anyone got any advice.
geposted Sat 05 Feb 11 @ 1:58 am
maybe check your security permissions and make sure they are all set to allow for all files on the external hard drive. after talking to the virtual dj team it worked for me.
geposted Mon 28 Mar 11 @ 4:44 pm
