I am getting a Dell inspiron 17 R and I plan on using virtual DJ with the computer but i am worried that the computer will not be powerful enough.
Intel® CoreTM i3 370M (2.4GHz/3MB cache
17.3" HD+ (1600 x 900)4GB3 Dual Channel DDR3
SDRAM at 1333MHz WLED Display with TrueLife
500GB4 hard drive (5400RPM
Integrated Intel® HD
Primary Battery
Lithium Ion Battery (6-Cell) – Up to 3 hours, 37 minutes of battery life*
Its not very fancy I know but its what i can afford right now. Is this good enough to support the system? are there other things i could buy to "vamp it up"?
Ps do plan on buying high speed hard drives
PLEASE HELP!!!!
Primary Battery
PLEASE HELP!!!!
geposted Thu 03 Feb 11 @ 12:31 pm
Powerful enough for what? You haven't really specified what you will be using it for...
geposted Thu 03 Feb 11 @ 9:03 pm
I plan on djing Mobile for a while using the virtual DJ software using a coffin which will have a behringer pro mixer djx400 b8044 and two numark ndx400s I mean will it be able to support it all?
geposted Fri 04 Feb 11 @ 11:35 am
