Topic: Need some help in choosing
im looking to upgrade my midi controller, have an ion icue at the moment, its ok, but want something with a bit more to it.
been looking at the Numark Omni and M-Audio Torq Xponent, also Hercules RMX, just cant make my mind up.
anyone any suggestions? something around the £300-£400 mark
cheers
geposted Thu 03 Feb 11 @ 4:10 pm
hmmmm...nevermind, i bought one regardless
sorry babes... if i'd have seen your request for help, i'd have responded... DOH!
what did you get in the end?
Seana
XXX
seeing as you called me babes...everything's cool lol!!
ended up splashing out a bit more and went for the pioneer SEP-C1
http://www.decks.co.uk/products/pioneer/sepc1
though i've literally just noticed in the last few minutes that it doesnt have a crossfader:(
any ideas on how well this would work with VDJ6? it comes bundled with DJS, but i had a quick look at that, and it's just not even on the same planet as VDJ
Taco...your going to need a mixer and soundcard to go with the Pioneer, as it's just a controller.
I'd have suggested the RMX in the price range you originally suggested - full MIDI controller with built in sound card and full mixer control and it's plug and play with VDJ.
Simon
thanks simon. didnt realise that at the time:(
can you recommend a good mixer that is compatable with this controller....something not too pricey as ive went way over my budget already:S
cheers
If you wish to be able to video crossfade, you will need a MIDI capable mixer such as Pioneer DJM-5000
Alternatively, you could map a knob that you do not need to use on the SEP-C1 to video_crossfader or a button to video_transition to performan an automatic transition to the appropriate deck. For basic mapping instructions, please see https://virtualdj.com/homepage/jpboggis/blogs/4149/VDJscript_Mapping.html
NOTE: To use MIDI controllers including the Sep-C1, you will need to upgrade to the full VirtualDJ Professional: https://virtualdj.com/buy/
The version that you have now is a limited edition (LE) of Numark Cue and will only work with the Numark Total Control.
thanks
had a look at the DJM5000....bit too much for me right now, my son would have to go without nappies for the next few months lol!!
opted instead for a DJM350
