Forum: Old versions
Topic: Mixtrack Pro/VDJ LE & Windows 7
I just got my mixtrack pro today (finally!!!!!!!!!!) on my macbook osx works fine........When I loaded up my bootcamp partition with windows 7, I install the software from the disk and then try to run the software it can't detect the mixtrack???? I'm confused so any help is greatly appreciated.
geposted Thu 03 Feb 11 @ 7:37 pm
Please ensure that you have installed the latest VirtualDJ LE from https://virtualdj.com/download/updates.html - The version on the CD may be older.
Do you have a Logitech webcam installed, or have you used one in the past? If so, these can cause conflicts and prevent MIDI devices from working under Windows.
start > right click computer > properties > device manager
find the mixtrack or any yellow flags in the usb section.
right click it/them and hit uninstall. disconnect the mixtrack and reinstall your software. once you reconnect the mixtrack it should be recognised.
if you leave the disc in you can goto add new hardware and point it to the disc to install the correct drivers.
hope this helps
It is the same version that is available for download 6.1.2
And blulite about 2 try what u said now.
I tried Blulite's suggestion and it didn't work the mixtrack pro is still showing up with a yellow flag. So please anyone who is using bootcamp on their macbook please help me.
been trying to set up the mixtrack pro on a friends laptop but keep getting the same problem. it works fine with my macbook tho. any suggestions???
