Forum: Old versions
Topic: upgrade question
Hi
I'm running CUE 5 on OSX 10.6. If I upgrade to VDJ 7, will I lose all my cue points on my tracks I've made?
Thanks
geposted Thu 03 Feb 11 @ 11:47 pm
Database information will be retained when upgrading. VirtualDJ v6 and v7 also use a new database file (VirtualDJ Database v6.xml), so your original v5 database will remain intact and unchanged.
If you own the full Numark Cue 5 (Not CueLE), then you can upgrade for free by going to https://virtualdj.com/users/edit.html and entering your Cue serial number in the box provided. The latest version can then be downloaded from the Download Center: https://virtualdj.com/download/updates.html
Otherwise, you will need to purchase/upgrade to VirtualDJ Pro from https://virtualdj.com/buy/ or download Home FREE from https://virtualdj.com/download/free.html if you will be using it for non-commercial (Unpaid) use only.
NOTE: You should backup your database on a regular basis if the information contained in it is important to you. If using external drives, you should also backup the database found at the root of each drive. Also, please ensure that you backup your entire music collection.
