For those of you having freezing/lockup issues with your 6000 - those issues have been solved. Go to denondjforums for the firmware fix. To save urself some time be sure u have the latest Java installed as u will need it for the update.
So u don't ask why ur left jog doesn't wrk after the update be sure to reset ur jog sensitivity on the left side by shutting down and hold load a, load b, and CF button and power on wait till power sequence finishes and reset ur left jog wheel to ur preference. directions are in ur manual. Good luck!
geposted Fri 04 Feb 11 @ 4:24 pm
This is already covered in detail in the hardware forum :)
geposted Fri 04 Feb 11 @ 5:00 pm
