Hi,
which is the best compatible sound card with a Samsung notebook, Intel i5, Windows 7 - 64 bit ?
I'm using VDJ Pro 7 full. The DJ IO sound card doesn't work, even with the new driver. It did with a Hewlet Pkd Widows XP.
Thanks !
Thanks !
geposted Sat 05 Feb 11 @ 8:57 am
@ Marco...I have a Dell Studio 15 with an Intel i5 running Win 7 64 bit and I have no problems at all using my DJIO - I just use the drivers that came shipped on the CD-ROM with the DJIO unit.
What problems are you having?
Simon
Simon
geposted Mon 07 Feb 11 @ 8:22 am
Have you tried installing the DJ IO on other USB ports ?
USB 3.0 ports sometimes do not work well and may require driver update to recognize older devices (you can see that they are USB 3.0 port because the inside of the connector is blue).
geposted Mon 07 Feb 11 @ 2:46 pm
Hey guys !! I just bought the Vestax typhoon with virtualDJ LE and a "Audio driver cd: ASIO4TYPHOON" that comes with in a box...so the problem is, I have the new HP envy beats 14" windows7 64bits...and on the box says its compatible but the audio driver ( sound card ?? ) isnt ( says just 32bits !! ) when I tested before install this audio cd, it works more or less...and after installed it, the software VirtualDJ works but doesnt when I plug in the controller ( typhoon ) on my computer...Should I install a audio driver 64 bits ?? is that the problem ? where can I download it ?? thanks guys !
geposted Wed 11 May 11 @ 10:09 pm
@ 3Beats
Go to: http://www.asio4all.com and DL the driver for 64 bits which is available now.
geposted Thu 12 May 11 @ 2:13 pm
deejay trim 4&6 card
geposted Fri 13 May 11 @ 7:33 am
@ 3beats I have the same problem and I tried downloading that software the last guy mentioned did you ever get the problem fixed? If so what did you do? by the way I'm also using the beats envy edition and vestax typhoon.
geposted Fri 16 Sep 11 @ 1:00 am
The following may help: https://virtualdj.com/wiki/Typhoon.html
Please also ensure that you have the most recent version of VirtualDJ LE for Typhoon installed. Register your LE serial number on the page https://virtualdj.com/users/edit.html and then go to https://virtualdj.com/download/updates.html
geposted Fri 16 Sep 11 @ 4:15 am
thanks but sorry it still doesn't work entirly right
geposted Fri 23 Sep 11 @ 12:45 am
I did that. I have 64 bits and the cd says 34? It work for a minute without the control and all of a sudden it wont up. I tired what was mentioned above. HOw can i get this program to work????
geposted Sun 23 Sep 12 @ 10:40 am
perki146 wrote :
I did that.
You did what?
What CD?
What works for a minute? What control? What won't up - and what does "wont up" mean?
What did you tire (sic)? There are lots of things above.
What program?
geposted Mon 24 Sep 12 @ 2:19 pm
