Hello all
I was looking at the Hercules Deejay Trim. Looks like a good sound card but if I
wanted to play a audio cd what are the steps to take. I don't see a thur input
on it
Thanks
on it
Thanks
geposted Sun 06 Feb 11 @ 11:10 am
Can any one help with this....?
geposted Mon 07 Feb 11 @ 1:32 pm
You connect your CD player to either inputs of the Trim (as you would for any other similar DJ soundcard) and use it as an external source.
But since you appear to own the Numark Mixdeck (which has input possibilities), why would need another soundcard exactly ?
geposted Mon 07 Feb 11 @ 2:43 pm
DJ Phatso
Thanks bro and yes I use the mixdeck but I also use CDJ for bigger gigs. Ok with my Serato sound card there is a
thur input on it to play off audio cds. With my M-Audio Conectiv you just turn the knob on top of it to play audio cds.
I am try to find out the steps to take for a friend of mine that has the Hercules Deejay Trim. With this sound card can you
play off audio cds...?
geposted Mon 07 Feb 11 @ 3:43 pm
Plug your CD player into one of the two audio inputs. Make sure the switch is set to line and not phono.
http://www.hercules.com/us/DJ-Music/bdd/p/102/deejay-trim-4-6/
geposted Mon 07 Feb 11 @ 10:53 pm
You can alternate between using timecode and audio CD by using the function Timecode_Bypass that can be assigned to your keyboard or a button on your controller
ex:
DECK 1 TIMECODE_BYPASS
ex:
geposted Tue 08 Feb 11 @ 1:36 pm
