Topic: Definition File for Hercules MK4
Hey guys and gals,
A friend of mine offered to give me his Mk4 because he has no use for it anymore. I was wondering if its possible (or if someone has it) to get the DEFINITION file for this controller (I have a custom map already, but I would like to see what is really going on here).
if anyone could help, i would be very grateful.
Thank you
geposted Mon 07 Feb 11 @ 2:20 pm
Since the MK4 is natively supported by VDJ Pro, it should appear automatically in the Controller tab, where you'll be able to modify the original mapping to your liking.
Sorry, the definition files for native supported devices are not available separately.
You can edit the mapping as above.
Full technical details about VDJscript and writing mappers/definitions can be found on the following page: https://virtualdj.com/wiki/VDJscript.html
Okay, great! Thank you for the help!
Best,
Alex
