Is there any way to use this impressive software inside VDJ??
http://www.izotope.com/products/audio/stutteredit/features.asp
geposted Tue 08 Feb 11 @ 12:31 am
Hmm......that kinda seems like the "Glitch" vst and that doesn't work with VDJ. Looks cool though. I would send an email with a link to the free Home Edition of VDJ to the creator asking them if its possible to make a patch or plugin.. You get better results that way I would imagine.
Just my thoughts
Huey
Just my thoughts
Huey
geposted Tue 08 Feb 11 @ 2:42 am
I've tried this and the VST itself works.
It has to be controlled via MIDI though IIRC, so you'll need to use a seperate MIDI device and prevent VDJ from using it.
geposted Tue 08 Feb 11 @ 4:42 am
So all I need is a separate MIDI device? I love the concept, but I don't want to plunk down the coin if I won't be able to get it to work.
geposted Tue 08 Feb 11 @ 9:00 am
I've not tested it fully - I've loaded the VST into VDJ and it activates and I can open the control window. But AFAIK Stutter Edit requires a MIDI device.
geposted Tue 08 Feb 11 @ 12:06 pm
How do you load the VST?
geposted Wed 09 Feb 11 @ 6:34 pm
I've tried this program a month ago and couldn't get it to work with VDJ...I was hoping it would.. I have some drum kits, I would like to sync with my music in VDJ...
Joey...
Joey...
geposted Wed 09 Feb 11 @ 6:58 pm
Joey...
Joey...
It is possible to use Stutter Edit in VDJ without midi Keyboard. Open the preset manager and trigger each preset with you mouse by clicking on it. or you can use a touchscreen monitor and trigger with your finger. (Similar to playing piano on iPad)
geposted Wed 22 Jul 15 @ 2:55 am
