Hello,
I've just installed VDJ7 Pro Basic and notified a very annoying thing for me. There are no more "Channel"-Numbers anymore above the Faders in the SAMPLES-engine/window. Each of the Sampler-channels is associated with an F1...F12 key on the keypad. But as there is no more numbering anymore in VDJ, it became very difficult to work with it (i.e. to intuitively find and press the dedicated F-key to play a Sample)!
How can I get the numbers back? I am using the default skin and I would like to stay with it, because it looks very "clear" and well structured.
Is it possible to modify the skin by myself?
(I have uncompressed the "VirtualDJ7-skin.zip"-files and tried to find the "Samples" section in the *.BMP files in order ro modify it - but it's not in there...)
Best regards,
mixmak
Best regards,
mixmak
geposted Tue 08 Feb 11 @ 1:57 am
