I have quite a few 1080p HD Videos that I would like to play but it seems like every time I do, Virtual DJ's video output slows the video down even though the music plays just fine. Is there any way to fix this or do I need to just upgrade my computer? Some things have been upgraded already btw but not sure if the video card is supposed to be capable.
Fujitsu
AMD Turion 64 X2 TL-60 2.0G
ATI Radeon Xpress 1150 IGP 256mb allocated memory
4gb DDR2 667 ram with 3gb usable after memory allocation to video (computer max's at 3.25 normally)
320gb hard drive
Windows 7 64bit
Fujitsu
320gb hard drive
Windows 7 64bit
geposted Tue 08 Feb 11 @ 6:02 am
If you haven't already, try shutting off 'Aero', (Control Panel\All Control Panel Items\Personalization: Choose a basic theme), and ClearType (Control Panel\All Control Panel Items\Display), these are both GPU hogs... shutting them off may speed things up for you.
also check out this page:
https://virtualdj.com/homepage/jpboggis/blogs/4094/Common_performance_issues_and_solutions.html
geposted Tue 08 Feb 11 @ 3:59 pm
ya, I have made sure my computer is using minimal resources. only item on startup is my anti-virus which is disabled whenever I'm using virtual dj. I guess the only requirement that isn't entirely met is that it's 256mb shared video memory with the ddr2 ram instead of dedicated. all other requirements are met or exceeded.
geposted Tue 08 Feb 11 @ 6:59 pm
