I am getting back into the DJ field. I have moved up from being a Vinyl Dj using dual Technics with Tascams for controllers to the American Audio VMS4. Overall I am impressed with my purchase. Needless to say I now need some speakers I can use to go mobile. I am on a serious budget so I have narrowed it down to one of these:
http://pro-audio.musiciansfriend.com/product/Kustom-KPC12P-12-Powered-PA-Speaker?sku=485593
Or:
http://pro-audio.musiciansfriend.com/product/Kustom-KPC15P-15-Powered-PA-Speaker?sku=485595
There aren't any reviews so I was hoping to get some honest opinions without any negative remarks.
Thank you
Or:
Thank you
geposted Tue 08 Feb 11 @ 9:11 pm
Those are really efficient entry level speakers, when I began back in the days I had the 15'' Kustom. Served me well, sold them afterwards to upgrade and they still work with the guy I sold them to.
Be carefull for the horns as they are sensitive. I had to change them once in 1 year. watch your Highs and you should be good!
Good luck and welcome back!
geposted Tue 08 Feb 11 @ 9:32 pm
Thanks a lot for the direction!
geposted Tue 08 Feb 11 @ 9:49 pm
