I would like to know if it's possible to change the key of a song in VDJ. Sometimes when I do Karaoke, someone would ask me to change the key but I have no idea how to do it or if it's even possible. I know it is possible in other karaoke software. Thanks
geposted Tue 08 Feb 11 @ 10:11 pm
great question, i've been wanting to ask this.
All I know is that you can change the pitch and without "keylock" the key will change too, but as you mentioned, I too want to know how to change the key without changing speed
geposted Tue 08 Feb 11 @ 10:31 pm
Take a look at the image below :)
geposted Tue 08 Feb 11 @ 10:41 pm
I guess I have the wrong skin
geposted Tue 08 Feb 11 @ 10:45 pm
Now I'm gonna have to do more research about how to map that knob to the pitch sliders so that it allows me to do switch back and forth from pitch to key adjusting.
So, anyone knows a good site to buy karaoke files to play with vdj?
geposted Tue 08 Feb 11 @ 10:47 pm
thank you very much homeboy. You can search the forum for karaoke sites it was already discussed.
geposted Wed 09 Feb 11 @ 12:12 am
What skin is that?
geposted Sat 28 May 11 @ 5:47 pm
standard vdj 7 2 deck skin
geposted Sat 28 May 11 @ 11:59 pm
KEY is in the "effects" section under the "player" & "loop" buttons. I love this feature. Finally I can mix in key. It works great.
geposted Sun 29 May 11 @ 1:03 pm
I have a DDJ Wego and am using Virtual DJ Pro 7. I was just wondering, how do i get the key of the song to stay that the modified key i set it to. Key changing on the wego acts like an effect so if i want the key of a song to be different, i cant use the turntables at the same time. Someone please help
geposted Wed 04 Sep 13 @ 3:46 am
This thread is a little old, and will be locked.
Locked by AMAHM
Locked by AMAHM
geposted Sat 10 Mar 18 @ 8:09 pm
