i just installed my 4-mx i have windows 7 i can her the music playing through my headphones but when i wana mix i cant hear the other track any hel would be great
geposted Wed 09 Feb 11 @ 3:44 am
Use the Cue to Mix knob (next to the headphone volume) to blend in the cue track and what is being played on the main output.
geposted Wed 09 Feb 11 @ 6:51 am
hi thanks all that seems to do is change the vol in my headphones i dont know why i cant cue the next track in my headphones
geposted Wed 09 Feb 11 @ 8:42 pm
Have you looked at the audio configuration menu in VDJ ?
You should have something like this:
- Input : Line In
- Output(s): Headphone
-Soundcard: DJ Console 4-Mx
- Input : Line In
geposted Thu 10 Feb 11 @ 6:40 am
my settings are that way if i turn the mix cue nob to CUE it just goes silent is there a button or somthing iam missing
geposted Fri 11 Feb 11 @ 2:03 am
You are pressing the CUE SELECT button for the deck you want first ?
If you don't tell to the software which deck you want to listen to, it's obvious that when in the CUE position, you will hear nothing...
geposted Fri 11 Feb 11 @ 5:52 am
mate thanks heaps got it work your info helped alot thanks
geposted Fri 11 Feb 11 @ 8:29 pm
