i just got a numark mixtrack evetything works good with virtual dj pro but once i use it for more then 10 mins the scatching stops working.anyone ever have this problem???
geposted Wed 09 Feb 11 @ 6:33 pm
mybad i spelled scratch wrong
geposted Wed 09 Feb 11 @ 6:42 pm
I think the trial version only works for 10 minutes with the Pro version. You have to use the version that came with the controller to work longer.
-David
-David
geposted Wed 09 Feb 11 @ 10:59 pm
i do have pro.everythink works good but the jog wheels cut out most of the time.its annoying me
geposted Wed 09 Feb 11 @ 11:24 pm
Language please.
If you're using VDJ pro, then it's usually best to register your serial and then grab the latest update from your download center.
Never used a mixtrack myself so I won't be of much use there I'm afraid. It sounds like a problem with the device though to me, maybe worth speaking to Numark?
geposted Thu 10 Feb 11 @ 2:32 am
i fixed it.just replaced it for a new one works great now
geposted Thu 10 Feb 11 @ 10:25 pm
Excellent :)
geposted Fri 11 Feb 11 @ 2:25 am
