ive got the hercules 4&6 usb device and cant get it to record when i send signal thru the input. before the upgrade from vdj6 to vdj7pro i could click on the config and have options on where to record from. now with vdj 7 i no longer have the option. ive configured the advanced options in the sound config for four decks as outputs and 1 input but i dont get anything from the line input when i try to record from the line input just what is playing on the decks for vdj. any suggestions?
geposted Thu 10 Feb 11 @ 11:05 pm
hie
i have recently installed vdj 7 on my pc and cannot find my recorded mixes. i have never had any problems with previous vdj versions. i set up the record path from config in the record tab, it shows its recording but when i search for the file afterwards i cannot find it. any suggestions??
geposted Fri 11 Feb 11 @ 5:03 am
Figured It out! Thanks For all your support!
geposted Sat 19 Feb 11 @ 12:16 am
