Hey everyone out there! Cud someone pliz help me with the script for changing FX parameters on the keyboard, I don't have a controller but I have mapped my keyboard to every possible action you can think of, but this has baffled me. Any help will be very much appreciated. Thanx
geposted Sat 12 Feb 11 @ 5:45 am
Here you go...
Increase the param 1 value
[KEY] - effect slider 1 +1%
Decrease the param 1 value
[KEY] - effect slider 1 -1%
Increase the param 2 value
[KEY] - effect slider 2 +1%
Decrease the param 2 value
[KEY] - effect slider 2 -1%
Use which [KEY] you want to map it to.
You have to keep the [KEY] pressed to increment or decrement the values.
Hope this helps
Simon
Hope this helps
Simon
geposted Sat 12 Feb 11 @ 9:31 am
