A few question for you guys :-)
Q1: Which one of these two products you would choose if you were to buy one and why?
Q2: Which company has a better reputation product durable wise?
Q3: Which of these two works good with VDJ?
Have you tested any of these two? which one did you like using and found user friendly?
cheers.....
cheers.....
geposted Sun 13 Feb 11 @ 3:43 am
if you got the poke get the 4-mx. the mixtrack pro is plastic and personally i think its poorly built.
both work really well with vdj though the mixtrack tends to be used more with traktor i think.
geposted Sun 13 Feb 11 @ 5:30 am
and how good are the review of this company called HERCULES? well im asking this as in i have always heard of technics, pioneer, numark and denon. never really knew about HERCULES or heard of it. are the products lasting and stuff?
geposted Sun 13 Feb 11 @ 6:48 am
the 4mx isn't so bad.
hercules made some good products.
lg,niklax.
lg,niklax.
geposted Sun 13 Feb 11 @ 11:56 am
hercules in general produce really good equipment, well audio wise anyway. their webcams are pretty crap but thats a different story.
hercules have a very good reputation when it comes to producing audio equipment. i dont think there would be anyone on this site thats not either got or had hercules equipment.
i can guarentee theres very little if any bad feedback about hercules controlers.
geposted Sun 13 Feb 11 @ 1:32 pm
thanks soo much guys for the inputs. i think ill drop the idea on mixtrack pro it anyways looks like a kids toy tho the size of the jog wheel and spacing of buttons were good in it. anyways made up my mind on the 4mx, i just hope i could do some scratching on it without any trouble since its size is soo small :-)
geposted Sun 13 Feb 11 @ 2:38 pm
I have Hercules controller and Numark MixTrack Pro. The Hercules are great little midi controllers, I've enjoyed my old MK2.
That being said, I LOVE the MixTrack Pro. If you want to scratch with a controller then you need to pick up the MixTrack Pro.
Great jogs works like a champ with VDJ.
Good luck,
T
Good luck,
T
geposted Mon 14 Feb 11 @ 8:27 am
just picked up a mixtrack pro this past weekend. so far its been very good, its light and portable but built very solid
geposted Mon 14 Feb 11 @ 1:39 pm
4mx
4mx
4mx
4mx
4mx
geposted Tue 15 Feb 11 @ 5:19 pm
but i wonder why no lights in the center of these controller like DJMs, PFL it is called i guess?.
geposted Thu 17 Feb 11 @ 2:00 pm
