Hello,
I am using the Virtual DJ FREE 7.0.2 and i put an .mp3 file to the desc and the desc diagram of the song does not saw
for more infos check this screenshot and you will understand sorry for my english.
http://img714.imageshack.us/img714/1309/virtualdj7bug.png
Here are the details of the song.
General
Complete name : C:\Users\DHMHTRHS\Desktop\diafora laika kinito\KARRAS - KSEKINIMA APO MIX .mp3
Format : MPEG Audio
File size : 198 MiB
Duration : 1h 26mn
Overall bit rate : 320 Kbps
Writing library : LAME3.98.4
Encoding settings : Lavf52.94.0
Comment : www.freemake.com
comment : www.freemake.com
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Duration : 1h 26mn
Bit rate mode : Constant
Bit rate : 320 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 198 MiB (100%)
- Thanks!
General
Format : MPEG Audio
File size : 198 MiB
Duration : 1h 26mn
Audio
Format : MPEG Audio
Mode : Joint stereo
Duration : 1h 26mn
Bit rate : 320 Kbps
- Thanks!
geposted Sun 13 Feb 11 @ 6:12 am
This is not a bug, it is because your track is 86 minutes long. The waveform will only show for tracks determined by this setting:
Config > Performances > Memory (change the load time)
However you need to have enough free RAM to load the track and show the waveform.
Keith
Keith
geposted Sun 13 Feb 11 @ 6:24 am
I changed to 999999 but the problem still exist.
geposted Sun 13 Feb 11 @ 7:16 am
What do you need the waveform for, to an 86 min song???
The song still plays normally. You will need too much memory as Keith said to load the waveform of such a large file. My i3, 4GB Ram laptop cant load it too, but what's the point?
geposted Sun 13 Feb 11 @ 11:48 am
The point is that the song waveform is not visible and too much difficult for not expert users to use it, Also i said before that i change it but didn't work, so if it is not a bug is something else that make the waveform not being visible.
geposted Mon 14 Feb 11 @ 10:05 am
If you want the waveform to work as a progress bar you can change the skin a liitle bit..
Find the songpos line and change the waveform="yes" to "no"
This will probably make the songpos to be displayed fully, but not as a waveform.
geposted Mon 14 Feb 11 @ 9:21 pm
