hey,i need help on how to move the cross fader without mouse?
Thanks
Thanks
geposted Sun 13 Feb 11 @ 8:29 am
click the fader bar, hold down the mouse button(left) and drag it left to right. though try using undermixing instead its loads better and easier too.
to under mix, leave the fader in the central position and use the volume controls and EQ to bring in your track.
hope this helps
hope this helps
geposted Mon 14 Feb 11 @ 2:18 pm
hey wat is EQ,anyway thanks!!
geposted Tue 15 Feb 11 @ 8:07 pm
to move the cross fader w/o the mouse, press page down or page up keys if you want it incremental. press ctrl+page up or down if you want it abruptly. also EQ satnds for equalizer. ; )
geposted Sun 20 Feb 11 @ 9:51 pm
Thanks man!!
geposted Mon 21 Feb 11 @ 2:54 am
EQ = Equalisation, equaliser...
or in other terms, low, mid and high range frequencies.
some people call them bass, vocals and trebel.
geposted Tue 22 Feb 11 @ 3:07 pm
