I'm not sure. I run VDJ with the mixdeck and can toggle in and out of scratch mode with the dedicated button on the Mixdeck. The scratching kind of sucks with the mixdeck, but I think messing around with the jogwheel sensitivity could help. Which skin are you using? I had some trouble when I switched to snother skin...but I don't remember which one. Try it with the standard VDJ skin and see if that help.
geposted Mon 11 Apr 11 @ 11:34 am
Hey Huey,
Great video review in the Mixdeck.I also have this unit and I overheard you describe that you were able to bypass the Mixdeck sound card???
I have a Virtualvinal sound card that I would like to use instead.Would you mind explaing how it can be bypassed and utilizing another card?
appreciate any info you can spare!
thanks
thanks
geposted Mon 11 Apr 11 @ 1:38 pm
@Lineman, Thanks ill have a post a video tonight on how to do it. Pretty much all you have to do is, plug in the sound card of your choice. Select it in the sound setup. Then run your rca's from the soundcards out to the MixDecks Aux in. On the mixer just move the selector to Aux and put the MixDeck in MIDI mode and your good to go. I do it this way cause like I said the MixDeck soundcard is just to quite for me. That Numark card should sound pretty good.
Hope that makes sense, ill still post the video later on tonight.
Huey
Huey
geposted Mon 11 Apr 11 @ 2:09 pm
Thanks Huey, I never liked it to much either..getting a slight hiss from it.I eliminated the pc,and tried 2 different sets of powered speakers and also all ground,and different power plugs...came to the conclusion its the sound card.I welcome the video bro.. but your explaination might suffice as well!
well here goes...
ok heres a question..if its in aux mode can the cd and usb still function this way? and how about the headphones?
well here goes...
geposted Mon 11 Apr 11 @ 2:48 pm
Yeah everything will still work but you have to move the selector on the mixer then switch it from MIDI mode to cd or usb which ever your gonna use. I'll show you that in the video aswell ;-)
Huey
Huey
geposted Mon 11 Apr 11 @ 3:23 pm
Ok I connected everything and it all worked fine..except I still get that hiss when I up the master volume just past 50% on the mixdeck.
using either sound card. I was hoping the virtualvinal sound card would eliminate that.It must be the mixer.
geposted Mon 11 Apr 11 @ 3:33 pm
I love my mixdeck too a have the rmx aswell as the vms but for overall usage Mixdeck for sure.
geposted Thu 14 Apr 11 @ 7:20 pm
Ok here's an update on my MixDeck, some big changes that I'm sure will help other.............
If you need any help just holla at me.
Enjoy
Huey
P.S. It will also work with the MixTrack, I tried it after I stopped recording. So rip it up fellas & ladies......
geposted Sat 11 Jun 11 @ 8:55 am
