Hey dj`s! I have a problem with recording and here it is:
Vdj is reducing BPM on recording. For example i need cut a part of track which BPM is 128, and after recording I have 88 instead of 128.
How can i fix this?
How can i fix this?
geposted Mon 14 Feb 11 @ 5:54 am
So.. nobody knows or what? I got to complete a mix at this week :D I really need
geposted Mon 14 Feb 11 @ 12:54 pm
maybe it doesnt have any length to calculate 128, u can manually change it
geposted Tue 15 Feb 11 @ 4:35 pm
I tried to record more than a minute and still nothing. Have the same 88 bpm.
If i configure it manually, it will plays too fast, already tried it(
P.S. Even Traktor has this annoying problem.
geposted Wed 16 Feb 11 @ 3:04 am
mabye that part of the song is 88 bpm. have counted it manualy?
geposted Wed 16 Feb 11 @ 3:10 am
No i didnt.
And i had recording at least 1 minute, so lenght is enough. So if this part of track is really 88 bpm, what should i do then?
geposted Wed 16 Feb 11 @ 6:04 am
load that piece you recorded on 1 deck, then load the original song on the other deck and make sure that it is at the right spot where you started your recorded piece from, then go to the bpm options of the recorded piece and under one of the tabs, click on copy from another deck
geposted Wed 16 Feb 11 @ 11:39 am
So the track itself is not slowing down (which is what it seemed you were saying) but the BPM display is wrong?
If so, why are you worried? Surely if it really was playing back that much slower (88bpm instead of 128) you'd be able to hear it.
geposted Wed 16 Feb 11 @ 4:04 pm
farhanashraf, thanks a lot!!! It worked out 4 me! Great!
groovindj, but i need to mix this 88 bpm part of track with another 128 bpm track. So thats was the problem)
geposted Fri 18 Feb 11 @ 3:53 am
